CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,159
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I was using the York rake trying to improve the steep uphill drive to my place. it's about 1000 feet, and the winter time and truck traffic (garbage, fuel, delivery etc.) makes for a bumpy ride.
This rake is the sulky type, with wheels out behind
So I adjust the "penetration" with the tractor 3pt lift after setting the implement level adjuster.
What I noted today was that the position lever control at the right hand of the operator had little response to initial movement. That is, positions number 0-3 were all the same, and at the lowered 3pt hitch position.
When the control lever was pulled to the greatest lift position, the lift arms were higher than I will ever need, so there is no loss of range.
I'm wondering how to set the position control feed back adjustment (under the seat) to obtain greater sensitivity in those initial position control lever settings.
I've not come across this adjustment in the literature I received with the tractor.
Anyone familiar?
ps
this Kubota tractor does NOT have draft control, only position control. The Hurlimann has draft control ;-)
Anyone familiar?
ps
