Kubota B26 won稚 boom in and stick in at the same time...
   / Kubota B26 won稚 boom in and stick in at the same time... #1
freezerburn
Alaska
B6100DP, B26, 1996 Arctic Cat Bearcat 550 liquid snowmobile with log towing chains, 2019 Home made log arch, 1983 Honda ATC200E
...Unless the stabilizers are up. Same with the loader- can稚 lift the front of the tractor up with the stabilizers down but with them up it will come right up a foot. Prior to adding a hydraulic thumb I didn稚 try the above functions to ascertain if this was a pe existing issue. After the thumb add on I changed the hyd oil and hyd filters then purged of air by cycling the steering wheel left and right as per the manual. The dipstick is yellow and slick and very hard to read with new oil on it..
The above symptoms seem to be a hyd fluid level issue but the level does appear correct on the dipstick but it痴 a slick stick and bright yellow and I知 thinking of using some 60 grit paper on it to make it potentially more legible..
Pic I hope?
Nope, ugh
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
Genie GTH-644 (A50490)
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
KUBOTA M7-132 LOT IDENTIFIER 31 (A53084)
KUBOTA M7-132 LOT...
