Kubota B26 won稚 boom in and stick in at the same time...
   / Kubota B26 won稚 boom in and stick in at the same time... #1
freezerburn
Bronze Member
Alaska
B6100DP, B26, 1996 Arctic Cat Bearcat 550 liquid snowmobile with log towing chains, 2019 Home made log arch, 1983 Honda ATC200E
...Unless the stabilizers are up. Same with the loader- can稚 lift the front of the tractor up with the stabilizers down but with them up it will come right up a foot. Prior to adding a hydraulic thumb I didn稚 try the above functions to ascertain if this was a pe existing issue. After the thumb add on I changed the hyd oil and hyd filters then purged of air by cycling the steering wheel left and right as per the manual. The dipstick is yellow and slick and very hard to read with new oil on it..
The above symptoms seem to be a hyd fluid level issue but the level does appear correct on the dipstick but it痴 a slick stick and bright yellow and I知 thinking of using some 60 grit paper on it to make it potentially more legible..
Pic I hope?
Nope, ugh
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
(2) 12-16.5 TIRES & WHEELS (A51248)
(2) 12-16.5 TIRES...
2018 JOHN DEERE 160G LC EXCAVATOR (A51246)
2018 JOHN DEERE...
(3) STEEL CARTS (A51248)
(3) STEEL CARTS...
UNUSED RAYTREE RMBC72-72" BLOCK CRUSHER (A51248)
UNUSED RAYTREE...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
