Kubota B26 Brake issues
   / Kubota B26 Brake issues #1
cg8544
Gardnerville Nevada
2015 Kubota B26 TLB, John Deere ZTurn 42"
I recently bought a used 2015 Kubota B26TLB. I recently discovered that the left brake is not functional. The pedal goes all the way in and does not engage at all. See attached photo. The linkage and turn buckle to adjust are attached and the problem seems to be at the gear box. The right brake is fully functional. But, if I lock the brakes together they do not function well since the right brake does all the work.
   / Kubota B26 Brake issues #2
If linkage from pedal to the rear axle case is intact, then problem exists within the axle case. Unless your handy with your hands tools, and relatively heavy components, should consider dealer for repair.
Here is parts diagram.
   / Kubota B26 Brake issues #3
WSM explanation of brake operation and repair
Dave M7040
  • forum B26 brake 1.pdf
  • forum B26 brake 2.pdf
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
John Deere 5055E (A53317)
John Deere 5055E...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
