3-Point Hitch kubota b2410 3 pt too low
   / kubota b2410 3 pt too low #1
Wild Turkey
I have a B2410 with turf tires. My 3 pt when all the way down drags the ground and it wont go high enough to use several of my implements.
I know its the low turf tires but. Has anyone found a better way to get more lift height. My all purpose plow works but I have to lift all the way up to clear the ground by 2" and plow at #7
   / kubota b2410 3 pt too low #2
You will find two sets of holes in the lower lift arms. Try the other set of holes, and you will find that the 3pt won't go as low, but will lift higher. I had the opposite problem with my B2620 when I tried to run my middlebuster as deep as I wanted. Now I have clip pins instead of the cotter keys installed so I can quickly switch back, and forth.
black Max power washer (A53421)
black Max power...
QA Hitch Plate (A56469)
QA Hitch Plate...
UNUSED FUTURE FT13C EXCAVATOR (A57192)
UNUSED FUTURE...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
