Kubota B2400 blade change problem.
   / Kubota B2400 blade change problem. #1
John Cole
NEWBURY
Kubota B2400
Hi,
I am having difficulty undoing the bolts that secure the 3 blades. I'm turning anticlockwise, but the whole spindle assembly is turning together rather than loosening. Any suggestions?
Thanks in anticipation.
John
   / Kubota B2400 blade change problem. #2
Try blocking the blades' rotation with a 2x4 placed between the blade and the mower deck.
Thanks for the advice. Unfortunately, I've tried jamming the blade but whilst the blade remains stationary, the whole spindle assembly still turns as one unit. I'll try a spanner on the top nut on the
drive belt wheel to see if that helps.
   / Kubota B2400 blade change problem. #4
If you had an impact wrench... You might have to figure someway to hold the top pulley.
Thanks for the advice, I'll give it a go. If i don't fix it this time I'll probably have to admit defeat and take it to the professionals. The grass is growing!!!
2012 Ford F150 Crew Cab Pickup Truck (A50323)
2012 Ford F150...
ABO TANK (A50854)
ABO TANK (A50854)
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
Komatsu PC138 (A50490)
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
