Stubee
I cut a lot of rough ground & thick cover with my B2320 hydro & LP 48" bush hog. Three or four times in 58 hours of running I've nailed a big rock hidden in tag alders/grass or pulled up a big log into the blades & the tractor stalls before I can raise the cutter, disengage PTO etc. It then starts & runs fine w. cutter once I've cleared anything & spun back up. Cutter is shear bolt, not slip clutch. Cutter grinds/shudders thru saplings etc just fine + miles of thick weeds.
I've read thru tractor & cutter manual stuff again & can't find any info on this.
I'm a bit surprised the shear bolt hasn't broken. Is this little 23HP Kubota designed to stall under sudden load like that? Thanks.
