Kubota B21 Temperature Gauge Reading
   / Kubota B21 Temperature Gauge Reading #1
dsilvia
Kubota B21
Hello, I have a Kubota B21 and my temp gauge just stopped working. It just lays there as it was not running. Can someone give me some ideas on what the issue may be.
   / Kubota B21 Temperature Gauge Reading #2
Wire has come unplugged from the sending unit on the engine?
Bad sending unit?
No power to the gauge circuit?-fuse?
Good Luck!
  • Good Post
Reactions: JWR
Thanks number two, I will check everything out
   / Kubota B21 Temperature Gauge Reading #4
Most of the older temperature gauges were actually a mechanical pressure gauge. What looks like a single wire inside of a coil spring cover is in fact a thin metal capillary tube carrying fluid pressure from a sender on the engine. Those gauges almost never go bad unless the capillary tube has been severly crimped - or cut and some sort or repair attempted.
There may also be an electrical connection on the gauge, but only for the gauge light bulb.
Or,.... it may be a fully electrically operated temperature gauge. If so, the easiest way to tell between the capillary pressure vs electrically operated type is that fully electric gauges do NOT have that peculiar coil spring wound cover protecting the metal capillary tube between engine and gauge.
Either guagetype will work, and being universal you can even replace yours with a similar gauge from an automotive store. However, be sure to get the type that has threaded adapters so that the sender that screws into the engine block will have the proper thread. A lot of gauges come with a little bag of those thread adapters.
Hope this helps,
rScotty
Hope this helps,
rScotty
Ok, now it appears that my fuel gauge is not working properly. It says there is approx 7/8th full, however I ran it for a while and have less then a half a tank, looked inside the tank. Could this be a fuse issue. If so, where do the fuses reside on the B-21. Thanks
   / Kubota B21 Temperature Gauge Reading #6
The diagrams I looked at don't show any fuses. Maybe someone else knows. When you start having to chase electrical issues, the first thing to do is trace clean up all the electrical connections you can find.
Especailly the ones behind the dash and around the ignition switch.
   / Kubota B21 Temperature Gauge Reading #7
The temperature sending unit could be checked with an ohmmeter.
See the WSM for details.
Perhaps it's giving incorrect readings to the gauge?
Good Luck!
   / Kubota B21 Temperature Gauge Reading #8
I have provided you with the 3 pages from the WSM explaining how the fuel and temp gauge work + wiring diagram for whole machine assuming it is equipped with OPC
Dave M7040
  • B21 gauges.pdf
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
LOT OF PALLET RACKING (A58374)
LOT OF PALLET...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2020 TAKEUCHI TB260 EXCAVATOR (A52709)
2020 TAKEUCHI...
2013 HYUNDAI Veloster (A56859)
2013 HYUNDAI...
