3-Point Hitch Kubota B21 3. lift
   / Kubota B21 3. lift #1
rprogers
Kubota B21
I have a B21 Kubota that needs a 3 point hitch (lower link, lifting rods, turnbuckles, top link etc). Have scoured the net, eBay and of course the local dealers. Unfortunately, Kubota only offers the B21 hitch in ala carte pieces that add up in the $650. range. I heard that the B26 assembly will work on a B21 (and is a couple hundred less), so I emailed Kubota to verify. Naturally, their response was "sorry but it's not compatable". Now, I understand Kubota's position, liability and such, but in the real world, does anyone know one way or the other if the B26 hitch will work on a B21? :confused:
   / Kubota B21 3. lift #2
I know that I bought a B26 3 point hitch package and that it contained everything I needed to hook up a 5' bush hog. I have not tried the box blade yet. So in my opinion it works just fine.
Thanks, that helps a lot. Just to clarify, you did install on your B21?
   / Kubota B21 3. lift #4
Yes, I hooked up a 5' bushhog to my b21 using the 3 point hitch package for a B26. I trailered the bushhog twice while attached to the B21 and mowed about 8 acres with it. The bushhog was borrowed from one of our larger farm tractors so it did not fit perfectly but it worked. It was a very heavy, older, John Deere bushhog. I believe I paid around $450 for the B26 package.
Sounds good. I think i'll do the same thing. My 4' brush hog should work fine with that setup. I appreciate the info, and if anyone else has anything they could share I would appreciate that too.
   / Kubota B21 3. lift #6
Also the 3 point linkage parts fit correctly in the B21 storage locations. So they must be the same sizes.
Thanks Bruce, it's amazing that the local dealers can't answer simple questions about their products, but thanks to this website people can share knowledge and ideas:thumbsup:
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
(1) 14ft Tarter...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
JOHN DEERE 8R 280...
Diesel Forklift (A51691)
Diesel Forklift...
