3-Point Hitch Kubota B21 3. lift
   / Kubota B21 3. lift #1
rprogers
Kubota B21
I have a B21 Kubota that needs a 3 point hitch (lower link, lifting rods, turnbuckles, top link etc). Have scoured the net, eBay and of course the local dealers. Unfortunately, Kubota only offers the B21 hitch in ala carte pieces that add up in the $650. range. I heard that the B26 assembly will work on a B21 (and is a couple hundred less), so I emailed Kubota to verify. Naturally, their response was "sorry but it's not compatable". Now, I understand Kubota's position, liability and such, but in the real world, does anyone know one way or the other if the B26 hitch will work on a B21? :confused:
   / Kubota B21 3. lift #2
I know that I bought a B26 3 point hitch package and that it contained everything I needed to hook up a 5' bush hog. I have not tried the box blade yet. So in my opinion it works just fine.
Thanks, that helps a lot. Just to clarify, you did install on your B21?
   / Kubota B21 3. lift #4
Yes, I hooked up a 5' bushhog to my b21 using the 3 point hitch package for a B26. I trailered the bushhog twice while attached to the B21 and mowed about 8 acres with it. The bushhog was borrowed from one of our larger farm tractors so it did not fit perfectly but it worked. It was a very heavy, older, John Deere bushhog. I believe I paid around $450 for the B26 package.
Sounds good. I think i'll do the same thing. My 4' brush hog should work fine with that setup. I appreciate the info, and if anyone else has anything they could share I would appreciate that too.
   / Kubota B21 3. lift #6
Also the 3 point linkage parts fit correctly in the B21 storage locations. So they must be the same sizes.
Thanks Bruce, it's amazing that the local dealers can't answer simple questions about their products, but thanks to this website people can share knowledge and ideas:thumbsup:
2013 ISUZU NRR 20FT FLATBED TRUCK (A52576)
2013 ISUZU NRR...
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2017 PETERBILT 567...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
