Kubota B20 or BX22
   / Kubota B20 or BX22 #1
Allan_Cen_Ont
The local Kubota dealer has both of these tractors that are used. the B20 has 1150 hrs and the BX22 has 1120 hrs and is asking $10,900 for it I don't know the price of the B20 . Both of these tractors have a loder and backhoe. What I am wondering is are both these tractors dedicated TLBs or can ya remove the backhoe to use 3pth implements with these tractors. Thanks for any help .
   / Kubota B20 or BX22 #2
Not sure, but I think the hoes come off. Make sure all the 3 point stuff come with them, which would be the arms.
   / Kubota B20 or BX22 #3
Both machines have removable hoes and are 2 very differant machines. the B20 is construction grade and has a new price near double of a new BX. If you are home owner you may like the bx as it is small and very usefull (but small) for more than yard work I would go with the b20 its old school tough. New bx25 is in the 15-18k and new b26 $27-35K. I have had a bx24 and it was a little small for commecial work and the B26 we is not always the perfect machine but it has done nothing but impress us so far.
   / Kubota B20 or BX22 #4
Unless you want a lawn mower go with the B20.
My B21 does not have a belly PTO for a belly mower. I believe the BX does.
The B20 is a stronger, larger, heavier tractor.
The backhoes come off of both.
   / Kubota B20 or BX22 #5
I've owned BX's and a B. The biggest difference is ground clearance. Not the only difference but the major difference. There is some weight difference but not as much as from B to L.
   / Kubota B20 or BX22 #6
Both machines have removable hoes and are 2 very differant machines. the B20 is construction grade and has a new price near double of a new BX. If you are home owner you may like the bx as it is small and very usefull (but small) for more than yard work I would go with the b20 its old school tough. New bx25 is in the 15-18k and new b26 $27-35K. I have had a bx24 and it was a little small for commecial work and the B26 is not always the perfect machine but it has done nothing but impress us so far.
But it's just right getting to those jubs the bigger tractors can't get into.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
CENTRAL PNEUMATIC  GAS 135 PSI (A52472)
CENTRAL PNEUMATIC...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
72In FEL HD Round Back Bucket (A52748)
72In FEL HD Round...
