Kubota B1750 clutch issues
   / Kubota B1750 clutch issues #1
Boomer
Hi tractor people. I just purchased a used B1750 4x4. 369 hrs. It had been sitting in buddies garage for a while not being used. Concrete floor unheated. I'm not certain for how long. Excellent condition. I'm expeiencing a little trouble with the clutch and shifting. I have adjusted the pedal play to specs. When disengaging the clutch and attempting to shift into gear.....grind!. Not always. Also, at times, when clutch is successfully disengaged and shifter put into gear.....low sounding grind ! I immediately shift into neutral, release clutch pedal and end of grinding. I would sure appreciate some opinions. Thank you.
   / Kubota B1750 clutch issues #2
Are you talking about shifting between high and low range. I am assuming it is a hydrostat.
I am a virgin tractor owner from up in Nova Scotia. So please bear with me. I have no reason to believe I have been sold a problem however I am having difficulty with the clutch or transmission. I spoke with the previous owner and he said he never had a problem and I believe him. It has sat unused for a while. The difficulty is in the main shifting not the high/low. The tractor is a Kubota B1750D 4X4. The guy I purchased it from picked it up via an auction where it was sold by the city of Halifax after it was damaged by Huricane Juan in 2002. Part of roof fell on it and did some cosmetic damage which was replaced. The guy didn't know what year it is and I don't. Whether it has an HST I honestly do not know. Hopefully someone else does know. It is a newer model. .....The Problem: I'm ideling at 1000RPM,stopped, clutch and attempting to shift into 1,2,3 or reverse. Sometimes I can shift easily into gear and other times not. Grind. It's as if the clutch is not disengaging. Also. When shifting is successfull, move tractor forward, depress clutch, still in gear ,and low grinding sound. I immediately shift into neutral and grinding sound stops. PTO in neutral. 2 or 4 wheel drive. High or Low speed. I'm a little worried about causing any damage so I'm leaving it sit. Any thoughts are appreciated. Thank you.
   / Kubota B1750 clutch issues #4
I have a b1750 but it is a hydrostat. What you are describing is not a hydrostat. It sounds to me like your clutch plate is wore out (not completely engaging or disengaging). You will probably have better luck posting in the kubota owning/operating part of this forum. It is now posted in the kubota buying/pricing forum. I have had a few questions and these guys on here are very helpful and knowledgable. Just repost in this in the other forum.
Good Luck
Thank you. I'm learning as I go. Your right it's not a hyrostat. The tractor is older than I thought. It's in such good shape.
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2022 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2022 ALLIANCE...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
1999 CASE 721C WHEEL LOADER (A53843)
1999 CASE 721C...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
