Kubota B1700 Piston removal - Do I have to remove engine to do this?
   / Kubota B1700 Piston removal - Do I have to remove engine to do this? #1
joestewart
Lafayette, LA
Deere 455
Hi, the local school has a donated Kubota B1700 and I've become the de facto mechanic in charge of fixing it. We suspect the rings are shattered because someone used ether to try and start it, and since that time, it has had no compression. I took the cylinder head off and the cylinder walls look pristine. I was all excited about tapping the pistons out the top of the motor, but was horrified when I looked under the tractor and discovered that the ?front driveshaft? prevents me from dropping the oil pan. Oh boy, this is getting complicated. That front driveshaft is encased within a tube that doubles as the hydraulic reservoir? Not sure and I don't want to start disassembling the shaft if I don't have to. Can't figure out the best way to access the crankshaft so I can loosen the connecting rod bearing caps and tap the pistons out the top. Front driveshaft is right in the way. Do I need to yank this motor off the tractor in order to remove the pistons? Allow me to beg for the relevant pages in the service manual, anyone? All advice appreciated. This is a Kubota B1700 four wheel drive with the three cylinder D905 diesel engine.
   / Kubota B1700 Piston removal - Do I have to remove engine to do this? #2
drop drive shaft. I dont think it has oil in it
Alright thanks. I looked at it a little further. The "tube" has no oil, but just keeps weeds / dirt out of the shaft. The oil pan is sandwiched between the two frame side rails, which are bolted directly to the engine block. The side rails have nuts which are welded onto the inner side, which prevent dropping the oil pan without splitting the tractor. Will perform a tractor split this weekend. Still begging for manuals though. Thanks for the reply!
   / Kubota B1700 Piston removal - Do I have to remove engine to do this? #4
dont think you have to split it, maybe remove side rails. to much work to split it
Thanks for that. Will proceed accordingly.
Alright, thank you for all the replies. Got the pan off and tapped out the pistons. Two of the compression rings were stuck in their grooves, but other than that, there does not appear to be anything wrong with the lower end of this motor! We are starting to feel like the two stooges here. I will unstick those rings and reinstall the pistons this coming weekend. Any recommendations on where to buy the head gasket and valve cover gasket (beyond the "local Kubota dealer" - I'm trying to avoid that place)?
2nd question: Does anyone know if the head gasket comes with that little button which seals the oil passage? Or is that little button a separate part? The button seals the oil passage between the cylinder head and the block.
Got the B1700 service manual in pdf format!
   / Kubota B1700 Piston removal - Do I have to remove engine to do this? #7
Joe
My neighbor has a B1700 that needs a new throwout bearing. We are going to need to split the tractor.
Where did you come across that Manual? I could sure use a first look at the parts configuration before going in.
Glad your engine woes are small!
tia
Cal
Joe
Cal
CalG, PM me. Include your email address and I'll send you a copy of the manual.
   / Kubota B1700 Piston removal - Do I have to remove engine to do this? #9
If you have gone that far get NEW rings and do all pistons with new rod bearings, don't get cheap now it will bite you in the butt
Again, thanks for that.
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A50854)
VERMEER VACTRON...
2018 RoGator 1100C (A51039)
2018 RoGator 1100C...
