Kubota B1700 odd starting problem
   / Kubota B1700 odd starting problem #1
JustAGuy
Clarkrange, TN
Kubota B1700
Good day everyone,
I have a Kubota B1700 with an unusual starting issue. When the tractor is cold, it (usually) starts up fine with no problems. But after I have been running it a while, when I turn the key, the ignition lights come on but no engagement of the starter. No clicking and the engine does not turn over at all. It rarely does this when it is cold, but almost always does it after it is warm. When it refuses to start, I am able to turn the key on and start it with a screwdriver by jumping it at the starter. Any thoughts on what the problem might be?
Thanks in advance!
   / Kubota B1700 odd starting problem #2
Defective battery cables, corroded cable connections at ground, starter or battery, failing battery, fried key switch, failing connector at solenoid wire at starter, failing solenoid. Try to remedy one thing at a time so you'll know (and tell the rest of us) what was wrong. Sounds like a simple process of elimination.
Jim
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
PALLET OF (2) THERMOKING TRIPAC UNITS (A50854)
PALLET OF (2)...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
1982 MACK RD685S HOTOILER (A50854)
1982 MACK RD685S...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
