Kubota B1640 FEL Control Valve Replacement?
   / Kubota B1640 FEL Control Valve Replacement? #11
I purchased the LV22RFSTKAB control valve for my b1630. Having issues with its operation. Pulling down on the stick there is a detent before reaching full downward travel. If left at this detent the boom is pushed down. Pulling the stick fully downward the boom will raise. Pushing up on the stick should lower it but it raises it also. The bucket works as it should. I've tried different hose configurations but no help.
Any ideas?
   / Kubota B1640 FEL Control Valve Replacement? #12
Update... Works great after trying various hose connection combinations. The instructions were opposite on the connections for lifting the boom. But I got it this morning after sleeping on it! :)
   / Kubota B1640 FEL Control Valve Replacement? #13
Good news! Sorry I missed your post from yesterday...
   / Kubota B1640 FEL Control Valve Replacement? #14
After getting the FEL to work properly I noticed the 3 point hitch was slow to react. Today I refilled the Hyd. reservoir (3 cups low after changing hoses) and the 3 point raises v-e-r-y slowww. I'm wondering if these controls have anything to do with this. I do not have the power beyond cartridge on the new controls. Would having this cartridge make the 3 pt. work? Doesn't seem like these controls should affect the 3 pt.
   / Kubota B1640 FEL Control Valve Replacement? #15
The PB sleeve might let more fluid pass through the valve, but I can't see it making that much of a dramatic difference. If there is that much restriction in the new valve, it will get VERY hot.
Can you add a drawing of how its plumbed? Or post some good pics?
   / Kubota B1640 FEL Control Valve Replacement? #16
Since I had to switch the boom hoses opposite of what the instructions called for I'm going to try switching the bucket hoses. If that doesn't help I'll switch the inlet & outlet hoses. There is also a hose for the return to reservoir that I disconnected to see if that'd help but realized there was no real pressure there.
   / Kubota B1640 FEL Control Valve Replacement? #17
Yet another update.
It's funny when you have something "Dawn" on you and a revelation follows!!! I switched the hoses back as per the instructions. The 3 Pt began working But (the dawn) I discovered these controls are for mounting on their side thus, pushing the stick L & R the boom raises & lowers and far right it goes into float mode. Push forward, pull back the bucket operates. I'm used to the pull/push to raise & lower the boom. So, either I remound/fab the controls to mount sideways or bite the bullet & re-learn the controls. :( Oh well... such is life........
   / Kubota B1640 FEL Control Valve Replacement? #18
EC, sounds like your seeing light at the end of the tunnel now, I'd re-fab the mount so the controls are standardized for safety and convenience.
   / Kubota B1640 FEL Control Valve Replacement? #19
If it weren't for adventures like these, Life Would Be Dull! :)
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2014 Jeep Cherokee Latitude SUV (A48082)
2014 Jeep Cherokee...
2000 WINNEBAGO FORD F550 RV (A50854)
2000 WINNEBAGO...
2008 Pro Pull Gooseneck Trailer (A50860)
2008 Pro Pull...
Club Car Electric Golf Cart (A48082)
Club Car Electric...
2022 Club Car...
