Hi,
New to the forum, and new to tractor ownership, so sorry for the stupidity! I recently bought a Kubota B7200 tractor with a backhoe and B1640 Front End Loader from my brother, with the knowledge that it needs some "work".
The control valve for the FEL is most likely shot, and I think I'd rather replace it than rebuild it. It sprays out a steady stream of oil on my feet at certain times, and gets stuck in the up position often.
The problem is that I'm having difficulty finding specs, and I know next to nothing about hydraulics. I've attached a diagram of the existing control valve from the user manual, and am wondering if anyone can suggest a source for a replacement that would work.
The manual only states "control valve, two spool with handle" and the specs say "one detent float position, power beyond circuit" and relief valve setting at 1450psi.
Any suggestions would be greatly appreciated!
