Snow Kubota B/L 2563 compatibility question
   / Kubota B/L 2563 compatibility question #1
L6060 Kubota
Does anyone know if I can use a Kubota B/L 2563 snow blower as a three-point mount on my L6060?
   / Kubota B/L 2563 compatibility question #2
It's my understanding this is a 3-pt model, so technically it will work. However it is only 63" wide which would be very narrow for your L6060. Also believe this was made for much smaller/lower HP tractors.
For a L6060 I'd want 6' minimum width and would be looking for something in the 7' range so the blower is wider than the tire tracks. Not really certain why you're interested in BL2563 for your application.
Correction added in edit:
Doing a bit more research it looks like this could model could be configured as a front mount blower. If the one you're interested in is from a front mount application, I'd worry about the RPM's needed to drive the blower in question.
Thanks, Moship. Yes, your info seems to confirm what I've been able to find out as well in that it was designed for smaller tractors. I'm not too concerned about the width in that I would probably use it just for cleanup work after using my 84" rear blade and front bucket for snow removal. The only reason I'm looking into it is there is one available at an upcoming local auction so thought I'd look into its feasibility. The RPM thing is a concern as well, so I'm thinking I will likely pass on it since it appears that even if I were able to make it work, it's really not the best match. Thanks again for the info.
Year: 2002 Make: Western Star Trucks Model: 4900 SA Vehicle Type: Truck Mileage: Plate: Body Type: (A51692)
Year: 2002 Make...
New Holland TS100 Tractor (RIDE AND DRIVE) (A50774)
New Holland TS100...
Ford Pickup NR (A50323)
Ford Pickup NR...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2012 Ram 4500 Versalift EL29N 29FT Bucket Truck (A50323)
2012 Ram 4500...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
