Kubota B 7300 Stalling
/ Kubota B 7300 Stalling #1
Marl Cobler
Kubota B 7300
I ran out of fuel but got that fied. She starts now but when I try to move her she goes about 10 to 15 feet and stalls out. HELP
/ Kubota B 7300 Stalling #2
You probably don't have it fixed, your close, but not there! You probably still have air in the system. Another may be you sucked trash from the bottom of the tank into the fuel pickup tube and it isn't allowing a constant flow of fuel that is sufficient to carry that engine, and it runs out of fuel after a few minutes.
Make sure you have a half tank of fuel, crank it and run it at about 1000 rpms and see if it will clear itself. If it stalls, wait 5 minutes, crank it again and after running, crack and release each fuel injector line and then close it. Got to get the rest of the air out!
Good luck!
David from jax
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
(2) 13.50x60 Tires and Rims (A65640)
(2) 13.50x60 Tires...
2019 Kubota SVL95-2S (A64126)
2019 Kubota...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
24ft. Folding Harrow (A65640)
24ft. Folding...
2022 EZ-GO ELITE...
