Kubota B 7300 Stalling
   / Kubota B 7300 Stalling #1
Marl Cobler
Kubota B 7300
I ran out of fuel but got that fied. She starts now but when I try to move her she goes about 10 to 15 feet and stalls out. HELP
   / Kubota B 7300 Stalling #2
You probably don't have it fixed, your close, but not there! You probably still have air in the system. Another may be you sucked trash from the bottom of the tank into the fuel pickup tube and it isn't allowing a constant flow of fuel that is sufficient to carry that engine, and it runs out of fuel after a few minutes.
Make sure you have a half tank of fuel, crank it and run it at about 1000 rpms and see if it will clear itself. If it stalls, wait 5 minutes, crank it again and after running, crack and release each fuel injector line and then close it. Got to get the rest of the air out!
Good luck!
David from jax
2017 Ford Explorer AWD SUV (A46684)
2017 Ford Explorer...
2011 14ft. Big Tex LX14 T/A 7 Ton Dump Trailer (A46683)
2011 14ft. Big Tex...
3pt 9ft Back Blade (A49251)
3pt 9ft Back Blade...
2025 Single Cylinder 40in Grapple Rake Skid Steer Attachment (A46683)
2025 Single...
2016 Kia Sedona LX Van (A46684)
2016 Kia Sedona LX...
Double Bottom Turn Plow (A48837)
Double Bottom Turn...
