Kubota B-26 bucket won't lift
   / Kubota B-26 bucket won't lift #1
Bucksaw
Ottawa
Kubota B-26
I have a 2008 B-26. I had the main pressure line from the pump spring a leak @ the weld right on the top of the pump. ( Apparently a common issue) I replaced the line and now my from loader arms won't raise.
If I try to raise the from bucket along with dumping or curling the bucket the arms raise fine. If I try to lower or raise them without curling or dumping the bucket it barely moves.
I tried cracking the hoses on the lift cylinders to see if there was any air but they seem fine. The oil level is also within the range on the dipstick.
Any suggestions??
Thanks
Derek
   / Kubota B-26 bucket won't lift #2
Remove the hoses at the cyl and see if you have flow. If not, check the QD's.
Operate about 5 to 10 times to expel any air.
Use a hyd gage and see if you have any pressure.
Does the 3pt work?
Did you try switching hoses on the loader valve?
20" Sea Container (A47384)
20" Sea Container...
2009 SolarTech Silent Messenger III Solar Message (A53117)
2009 SolarTech...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2004 Sterling Tack Truck (A52384)
2004 Sterling Tack...
Miller Curbilder, Kohler Engine (A52384)
Miller Curbilder...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
