Kubota B-26 bucket won't lift
   / Kubota B-26 bucket won't lift #1
Bucksaw
Ottawa
Kubota B-26
I have a 2008 B-26. I had the main pressure line from the pump spring a leak @ the weld right on the top of the pump. ( Apparently a common issue) I replaced the line and now my from loader arms won't raise.
If I try to raise the from bucket along with dumping or curling the bucket the arms raise fine. If I try to lower or raise them without curling or dumping the bucket it barely moves.
I tried cracking the hoses on the lift cylinders to see if there was any air but they seem fine. The oil level is also within the range on the dipstick.
Any suggestions??
Derek
   / Kubota B-26 bucket won't lift #2
Remove the hoses at the cyl and see if you have flow. If not, check the QD's.
Operate about 5 to 10 times to expel any air.
Use a hyd gage and see if you have any pressure.
Does the 3pt work?
Did you try switching hoses on the loader valve?
2013 INTERNATIONAL REEFER TRUCK (A53426)
2013 INTERNATIONAL...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2007 Toyota Tundra 4WD Pickup Truck (A53117)
2007 Toyota Tundra...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
5' Box Blade (A50123)
