Oil & Fuel KUBOTA B 21 FUEL INJECTOR PUMP REBUILD KIT
   / KUBOTA B 21 FUEL INJECTOR PUMP REBUILD KIT #1
Clarkschapel
Huntington, AR
B21 kubota
I remove the injector pump and found these numbers on it 16032 63011 96506 ZEXEL, but it has not helped me to find a rebuild kit.
Look at the attachment I believe it is a PFR type Pump inline, if anyone can help with a kit number please. Thank you Clarkschapel
   / KUBOTA B 21 FUEL INJECTOR PUMP REBUILD KIT #2
   / KUBOTA B 21 FUEL INJECTOR PUMP REBUILD KIT #3
Ask for joel Schenk at Conestoga Diesel.
Thanks for the responses, I decided to take the injector pump to an injector service center and have it rebuilt.
cost was about $190.00 bucks so now I have installed and Bled the fuel lines.
Engine started and did not want to shut off with ignition switch,so I shut the engine down by closing off the fuel line.
I will try again in the am to Bleed the lines again and again restart the engine, hope i can shut it off with key this time?
   / KUBOTA B 21 FUEL INJECTOR PUMP REBUILD KIT #5
Check your stop solenoid electrically and mechanically for correct operation, you would have removed it.
   / KUBOTA B 21 FUEL INJECTOR PUMP REBUILD KIT #6
Yeah, what he said.
Bleeding the lines won't help your problem.
There should be a stop solenoid. You had to mess with it to remove the injector pump.
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2015 INTERNATIONAL DF677 (A52472)
2015 INTERNATIONAL...
BESTWAY AG VSK35 LOT NUMBER 126 (A53084)
BESTWAY AG VSK35...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
