Kubota Auto throttle
/ Kubota Auto throttle #1
nebraskasparks
Northern Illiniois
2010 Kubota L5740 HST and JD X734
Anyone know how to adjust the autothrottle on the L5740?
I haven't used it much while breaking in the engine...it seemed like it was giving me way too much power for what I was doing when it was first delivered so I shut it off.
I turned it on again today after not using it for about one month and it is in fact adjusted/not adjusted for too much power.
All ears.
/ Kubota Auto throttle #2
If you open the hood and remove the 'passenger's side' panel you'll see two cables, the upper one is the cable you'll want to loosen.
/ Kubota Auto throttle #3
It looks gold in this picture and the other silver but they are both the same color. Loosen it up, adjust it, try it out, and readjust until you find a point you like. Don't worry about the cable being loose since when one cable is pulled on the other is designed to loosen up.
Many thanks...I'll get back to you after I get it done. Thanks for the picture...1 picture is worth about two paragraphs of words.
Thanks again.
/ Kubota Auto throttle #5
Do you have a loader? I have seen a few pinched by the subframe.
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
2025 66in Swict Bucket Skid Steer Attachment (A64553)
2025 66in Swict...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
