Kubota Auto throttle
/ Kubota Auto throttle #1
nebraskasparks
Northern Illiniois
2010 Kubota L5740 HST and JD X734
Anyone know how to adjust the autothrottle on the L5740?
I haven't used it much while breaking in the engine...it seemed like it was giving me way too much power for what I was doing when it was first delivered so I shut it off.
I turned it on again today after not using it for about one month and it is in fact adjusted/not adjusted for too much power.
All ears.
/ Kubota Auto throttle #2
If you open the hood and remove the 'passenger's side' panel you'll see two cables, the upper one is the cable you'll want to loosen.
/ Kubota Auto throttle #3
It looks gold in this picture and the other silver but they are both the same color. Loosen it up, adjust it, try it out, and readjust until you find a point you like. Don't worry about the cable being loose since when one cable is pulled on the other is designed to loosen up.
Many thanks...I'll get back to you after I get it done. Thanks for the picture...1 picture is worth about two paragraphs of words.
Thanks again.
/ Kubota Auto throttle #5
Do you have a loader? I have seen a few pinched by the subframe.
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2017 DITCH WITCH JT20 HORIZONTAL DRILL (A63276)
2017 DITCH WITCH...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
