kubota ac
   / kubota ac #1
dwight jr
southern middle tn
kubota l3800-m9000-jd4430
my m9000 ac compressor is not turning, when i put in some coolant it starts turning but when the can is empty it stops. please help im too hot!
   / kubota ac #2
Sounds like you have a bad leak. The compressor will not run with low pressure.
You will need to find the leak.
I am not that well versed in ac repair but after the leak is found youll probably need to pull a vacuum on it to remove the moisture and you may have to replace the dryer. Like I said not very knowledgable on ac.
If you do not have the equipment youll have to take it to be repaired.
   / kubota ac #3
Common misconception; AC doesn't cool so "add some gas". What comes in the can is liquid refrigerant not "coolant". If you do not understand thermodynamics and the refrigerant cycle and have the proper tools/equipment it is not a good DYI project. "Adding gas" can create other potentially expensive problems if the system is not under charged. A lot of systems today have a critical amount refrigerant charge that is measured in ounces. The +/- amount is very small. Even at HF; an equipment set is round $500 if you then know how o use it. Don't wast your money on a single stage vacuum pump as they will not get below the water evaporation point.
Ron
   / kubota ac #4
To properly diagnose an AC system or add refrigerant one needs manifold with both high & low pressure gauges with proper hoses/connectors. .Many tractor AC ""not cooling problems"" are created from dirty,stopped up cab filters,radiators,condensers &/or evaporators. From what I've read Kubota M9000 needs very clean AC system components to cool. I know the M4900 AC system I once owned required more cleaning to cool well than my M7040 that I now own.
17001 (A44571)
17001 (A44571)
Mahindra 24 HST 4x4 Tractor with Belly Mower (A44391)
Mahindra 24 HST...
2006 Caterpillar 302.5C Mini Excavator (A42742)
2006 Caterpillar...
2018 JOHN DEERE 210G LC HYDRAULIC EXCAVATOR SN:1FF210GXCJF525728 powered by John Deere diesel (A40020)
2018 JOHN DEERE...
1995 INGERSOLL RAND SD100D 84" SMOOTH DRUM ROLLER, S/N 141336, CANOPY, HOUR METER READS 3896 HRS (A40517)
1995 INGERSOLL...
1981 Chevrolet Grain Truck (A40783)
1981 Chevrolet...
