Kubota 7100 Tractor..PLEASE HELP
   / Kubota 7100 Tractor..PLEASE HELP #1
jere7782
Fulton Ky
Kubota 7100
I recently bought a 7100 series tractor used..
It is a diesel only 2wd..
I been using it for about a month now.. Original owner stated it had all fluids checked and changed.
I went to went to drag my driveway. Upon starting the tractor it started making a loud noise. It would not go forward or reverse.
I tried to turn on pto, it would not turn either.
I bout it for 1700 and (493) hour meter dont work.
I have mowed my yard etc and never had any problems.
I am hoping it is not a major costly repair.. any ideas?
Thank you all.
Yeah it is hydrostat
   / Kubota 7100 Tractor..PLEASE HELP #4
Check the drive shaft to the hydrostatic and determine if it is turning.
Does the three point hitch work?:)
Does the noise stop if you push the clutch in?:)
How do i check drive shaft?
Also hydrolics 3pt goes up and down but pto does not turn.
Alao clutch is pressed still makes loud noise
   / Kubota 7100 Tractor..PLEASE HELP #6
To check the drive line try and turn it with clutch depressed and hydro in neutral.
Any change when the hi/neutral/low positions are selected on the hydro?
With pto engaged/disengaged will it turn by hand?
Sorry about all questions and no help:eek:
i pressed the clutch and turned pto on...
it moved really slow... i moved it with my hard but was not easy..
i took a video and a pic of some parts that i thought were important..(im not a mechanic)...
   / Kubota 7100 Tractor..PLEASE HELP #8
Check the hydro fluid level.
Have you changed the hydro fluid and or filter?
Is the transmission possibly between ranges? My Kubota tractors range selector can be between ranges like in neutral.
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
Mobile toilet (A53424)
Year: 2006 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 86,950 Plate: Body Type: 4 (A55788)
Year: 2006 Make...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
