Mowing Kubota 7100 hydro power
   / Kubota 7100 hydro power #1
deerefan
louisiana
1952 8N, 2005 JD 5103
My father has a Kubota 7100 hydro 4wd. I think they gave roughly 13 pto hp and he would like to run a 5 ft finish mower. I feel it may be a bit much and suggested a 4 ft as he already had a 4 ft bush hog. Thoughts?
   / Kubota 7100 hydro power #2
I would say 5 ft would be the max cutting normal grass. The weight differences between a 4' versus a 5' is usually ~100 lbs.
   / Kubota 7100 hydro power #3
I run a 5' finish mower and a 5' brush hog on mine with no problems.
What痴 funny is it is easier to find 5ft stuff in stock here at the local dealer and tractor supply. I have been using his tractor some around the farm, getting sold on hydro. Very capable small tractor.
   / Kubota 7100 hydro power #5
I run a 5 foot finish mower with my B7200 and my dad has a b7100 with a 60” mm and both machines do pretty good power wise.
I got the info from tractor data-are they really only 16hp/13pto hp? Seems a bit stronger than that.
   / Kubota 7100 hydro power #7
Will do fine if you take your time.
Hope your friend B7100 has some sort front weight/weights if mowing slope.
   / Kubota 7100 hydro power #8
I ran a Woods RM59 60" 3 pt mower behind my B7100HST for many years with no problem. I'd have to slow down a bit in heavy grass or on a slope though.
Thanks guys. We will likely go with a 5ft, just wanted to confirm it will not be too much.
   / Kubota 7100 hydro power #10
Our B 7500 is similar in size and it came with a 60-inch mid-mount mower on it. We have also run a 60 inch Bush Hog on the back, but that's a little bit heavy and you have to go slow in heavy grass.
Aaron Z
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
Craftsman II 42in Riding Mower (A51694)
Craftsman II 42in...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
19200 (A50324)
19200 (A50324)
