Loader kubota 7040su questions
   / kubota 7040su questions #1
case245
Platinum Member
pa
kubota 7040sud
i have a 7040su does the tractor have a limited slip diff up front or is it an open diff the dealer dont know if it does or not
   / kubota 7040su questions #2
No it does not. You've asked this question at least once before. Wishing it won't make it have it.
Or...go out in the mud, put it in 4WD, and stomp on it. If both fronts spin then you have it.
Or...jack up the tractor with all four wheels off the ground and in 4WD. Engage the gear and see what happens. Hopefully, falling off of the jacks is not one of the things to happen.
Or...go to the Kubota website and look at the specifications for the M7040su compared to the M7040HD.
   / kubota 7040su questions #3
Simple easy way to tell:
Raise the front wheels, By hand turn the left wheel forwards, if the other wheel turns the Same direction you do... If it turns opposite, you do Not. KennyV
   / kubota 7040su questions #4
Bingo. Use you FEL to raise the front wheels in the air. Should take all of 2 minutes to see if you have a LS or open
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
UNUSED FUTURE XJ3T-3T HYD THUMB CLAMP (A57193)
UNUSED FUTURE...
CATBKTSSL_78 (A55787)
2026 Kearney 7' x 20' Trailer (A53317)
2026 Kearney 7' x...
2021 Frontier GM1084 (A53317)
2021 Frontier...
Giyi 48" Mini Excavator Root Rake (A56469)
Giyi 48" Mini...
