Loader kubota 7040su questions
   / kubota 7040su questions #1
case245
Platinum Member
pa
kubota 7040sud
i have a 7040su does the tractor have a limited slip diff up front or is it an open diff the dealer dont know if it does or not
   / kubota 7040su questions #2
No it does not. You've asked this question at least once before. Wishing it won't make it have it.
Or...go out in the mud, put it in 4WD, and stomp on it. If both fronts spin then you have it.
Or...jack up the tractor with all four wheels off the ground and in 4WD. Engage the gear and see what happens. Hopefully, falling off of the jacks is not one of the things to happen.
Or...go to the Kubota website and look at the specifications for the M7040su compared to the M7040HD.
   / kubota 7040su questions #3
Simple easy way to tell:
Raise the front wheels, By hand turn the left wheel forwards, if the other wheel turns the Same direction you do... If it turns opposite, you do Not. KennyV
   / kubota 7040su questions #4
Bingo. Use you FEL to raise the front wheels in the air. Should take all of 2 minutes to see if you have a LS or open
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52128)
NEW Work Saver...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
Bush Hog 176 3 pt Blade (A50514)
Bush Hog 176 3 pt...
