kubota 5700
/ kubota 5700 #1
SFDK
Hi
I am interested in buying kubota 5700 and I like me who you gave your opinion me on this tractor
/ kubota 5700 #2
We have an M5700 at work. The guys that use it seem to like it. It is still pretty new with only about 700-800 hours on it. We have had to put a seal kit in one hydraulic cylinder on the FEL.... but that is the only repair to date.
/ kubota 5700
¿the tractor consumes much?
approximately whatever to the hour
thanks
/ kubota 5700 #4
I've been happy with mine. It's about five years old with 700 hours. I've never tried to measure the fuel consumption, because I don't use it that much. For constant high-rpm and high-load work, like bush hogging, I'll take a guess at about 1.5 gal/hr. For low-rpm work, it's substantially lower.
Rick
/ kubota 5700 #5
I just mowed down my field of waist high hay with a bush hog that took me 18hrs. of actual time and I used 18 gal. of fuel with my 5700.I only have a little over a 100 hrs. on mine but no issues so far , tractor runs fine.I don't run the tractor at quite full rpm pto speed but at 1 gal. per hr. that's not bad.I only have a 6ft. bush hog and run it in 4th gear low range as some of my field is a little bumpy.I keep the blades sharp so the hay cuts very easily and could easily go at a faster pace if it wasn't for the bouncing around.I no longer use the hay so I just let it lay.The 5700 seems to be a fine tractor.
/ kubota 5700 #6
I have a 10 year old M5400 (basically same tractor). Don't have many hours on it especially for it's age but have never had a problem.
/ kubota 5700 #7
I have a 4900 and it has been great. The 5700 is virtually the same machine. Zero complaints.
