kubota 5700
   / kubota 5700 #1
SFDK
Hi
I am interested in buying kubota 5700 and I like me who you gave your opinion me on this tractor
   / kubota 5700 #2
We have an M5700 at work. The guys that use it seem to like it. It is still pretty new with only about 700-800 hours on it. We have had to put a seal kit in one hydraulic cylinder on the FEL.... but that is the only repair to date.
   / kubota 5700
¿the tractor consumes much?
approximately whatever to the hour
thanks
   / kubota 5700 #4
I've been happy with mine. It's about five years old with 700 hours. I've never tried to measure the fuel consumption, because I don't use it that much. For constant high-rpm and high-load work, like bush hogging, I'll take a guess at about 1.5 gal/hr. For low-rpm work, it's substantially lower.
Rick
   / kubota 5700 #5
I just mowed down my field of waist high hay with a bush hog that took me 18hrs. of actual time and I used 18 gal. of fuel with my 5700.I only have a little over a 100 hrs. on mine but no issues so far , tractor runs fine.I don't run the tractor at quite full rpm pto speed but at 1 gal. per hr. that's not bad.I only have a 6ft. bush hog and run it in 4th gear low range as some of my field is a little bumpy.I keep the blades sharp so the hay cuts very easily and could easily go at a faster pace if it wasn't for the bouncing around.I no longer use the hay so I just let it lay.The 5700 seems to be a fine tractor.
   / kubota 5700 #6
I have a 10 year old M5400 (basically same tractor). Don't have many hours on it especially for it's age but have never had a problem.
   / kubota 5700 #7
I have a 4900 and it has been great. The 5700 is virtually the same machine. Zero complaints.
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
2006 Mastercraft S-05-1142 (A50120)
2006 Mastercraft...
CFG Industrial MX15RX (A50121)
CFG Industrial...
