kubota 5040 FEL
   / kubota 5040 FEL #1
sgipson
south mississippi
ford 3600 1974
After working in some thick brush the FEL will not raise or lower when the 3p
hitch is fully raised. If I push the lift lever down about 1/2 way the FEL with work properly. If the 3p hitch is raised fully the FEL will only lower by pushing the FEL lever all the way forward to the float position. Then when I try to lift the FEL there is a popping sound from the FEL hydralic lines.
   / kubota 5040 FEL #2
Try this first: Unplug ALL on the QD's (quick disconnects) that feed the loader and plug them back in. It is very possible one got snagged and is now not seated fully.
   / kubota 5040 FEL #3
Check for something blocking the 3 point from going to full height. If it cannot get there and you have the control lever all the way up, the system will go into relief.
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
2007 Freightliner Business Class M2 Rollback (A47384)
2007 Freightliner...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2008 Peterbilt 389 Tandem Axle Road Tractor (A47384)
2008 Peterbilt 389...
2021 CATERPILLAR TL1055 TELESCOPIC FORKLIFT (A51242)
2021 CATERPILLAR...
