Kubota 4x4 front drive axle????
   / Kubota 4x4 front drive axle???? #1
Kays Supply
Southern Illinois
Iseki TA 207
A friend just brought his new Kubota 4x4 by to show me. I didn't get the model number but it was a 32hp 4x4 Hydrostat. When I looked at the front drive axle it didn't have a differential. It was the strangest looking design I have ever seen. It looked like a two wheel drive front end. It had a drive shaft and the 4x4 type gears at the wheel. Can anyone tell me a place on the net to see a mechanical drawing of how the differential works on these new Kubotas?
   / Kubota 4x4 front drive axle???? #2
Hi They do have a diff. it is loaded from end of tube. I was very interested in this also as I build gear cutting machines for a living. You can go to kubotabooks.com and look at the parts manuals. Larry
Thanks, that is a pretty good site. I found out it was a B3200. That model isn't in the list at that site. I found some others that were like it. I still can't believe that a differential will fit in a small straight tube like it does.
   / Kubota 4x4 front drive axle???? #4
Remember there are two gear reductions from the dif to the front spindle. On my BX2230 the ratio is 5 to 1. Front axle does five revs for every one rev of the spindle. The differential only sees one fifth the torque on the spindle.
I don't know about the B3200, but on the B3030, the ratio is 8.52 to 1.
Makes quite a difference in the sizing of the diff.
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A49461)
2011 Kenworth T300...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
