Kubota 4x4 front drive axle????
   / Kubota 4x4 front drive axle???? #1
Kays Supply
Veteran Member
Southern Illinois
Iseki TA 207
A friend just brought his new Kubota 4x4 by to show me. I didn't get the model number but it was a 32hp 4x4 Hydrostat. When I looked at the front drive axle it didn't have a differential. It was the strangest looking design I have ever seen. It looked like a two wheel drive front end. It had a drive shaft and the 4x4 type gears at the wheel. Can anyone tell me a place on the net to see a mechanical drawing of how the differential works on these new Kubotas?
   / Kubota 4x4 front drive axle???? #2
Hi They do have a diff. it is loaded from end of tube. I was very interested in this also as I build gear cutting machines for a living. You can go to kubotabooks.com and look at the parts manuals. Larry
Thanks, that is a pretty good site. I found out it was a B3200. That model isn't in the list at that site. I found some others that were like it. I still can't believe that a differential will fit in a small straight tube like it does.
   / Kubota 4x4 front drive axle???? #4
Remember there are two gear reductions from the dif to the front spindle. On my BX2230 the ratio is 5 to 1. Front axle does five revs for every one rev of the spindle. The differential only sees one fifth the torque on the spindle.
I don't know about the B3200, but on the B3030, the ratio is 8.52 to 1.
Makes quite a difference in the sizing of the diff.
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
