Tractor Sizing Kubota 3800 and JD3038E
   / Kubota 3800 and JD3038E
Thank you for your thoughtful posts.
   / Kubota 3800 and JD3038E #12
As for cutting 15 acres and size tractor / mower needed. My retired brother in law cut our combined ownership of 42 acres of heavily overgrown pasture and at the time, weeds and small saplings with a 750 John Deere (19 PTO HP)and a 4 foot bush hog. I think it took him about a week but he didnt have anything else to do and besides, it was too rough to go fast anyway so a more powerful tractor would not have helped in speed but of course more width is always good for time reduction. It is really easy now to go way overboard (this from one person who has been there) with needed HP when you look at tractors and capacity. Myself, I have way more tractor than I need for mowing, grading roads etc but I have to say that sometimes even 70HP is not enough like when I was trying to pull out a stuck dump truck loading with gravel but I did eventually get him out.
My Dad farmed 40 acres with a then new 8N Ford which was 1000% better than a mule team so it can be done. Man how far have we come in one generation.
   / Kubota 3800 and JD3038E #13
I spent weeks comparing these 2 tractors. For me I ended up with a left over L2800 that the dealer had on the lot still but I got the new LA524 loader that comes on the new L3800. Some things about the John Deere was that it was all plastic, for me I'd rather have dents in the body panels than cracked plastic. The rear casing on the JD was cast aluminum which i'm sure is probably strong but not as heavy as the L3800 cast iron's. The big thing was the loader specs and weight of the machine. For one the loader on the bota is a quick attach the JD isn't and the bota loader had more balls and lift height if I remember correctly. Think the lift height was like a foot higher maybe more and maybe like 200 more lbs of lift. Wasn't to impressed with the fit and finish on the JD. Just my 2 cents.
-Matt
   / Kubota 3800 and JD3038E #14
In ideal conditions, I can cut about 1.5 acres/hr with my 6ft MX6. If you have all day to cut 15 acres, more power to you. However, I would certainly love to have a 10ft cutter if I had the cash! :thumbsup:
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
1293 (A58374)
1293 (A58374)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2013 International Bucket Truck (A55973)
2013 International...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
