Kubota 3000 series Zerk fittings
   / Kubota 3000 series Zerk fittings #1
Tony H
Platinum Member
Summit, NY
JCB MIDI CX
Neighbors 3540 tractor: He's got some bad Zerk fittings. I have a Draw full of Zerks that I collected over the years. Is the thread sizes on the kubota, standard, metric or British?
   / Kubota 3000 series Zerk fittings #2
I assume you mean a L3540? Are the fittings on the tractor or an attachment like the loader or backhoe?
   / Kubota 3000 series Zerk fittings #3
Tractor will be metric as are most pto driveline fittings. If it's a Kubota loader they will be as well.
   / Kubota 3000 series Zerk fittings #4
I've run into sae thread fittings on some Kubota loaders since a lot are made in the US, I've had some tractor mounted fittings be metric, especially if it was a Japanese built tractor like the L3540.
   / Kubota 3000 series Zerk fittings #5
I first got flustered with used M5030 loader that was probably made in Canada. Not SAE so bought a metric assortment. They didn’t work either. They were 1/4” British taper threads. 1/8” SAE and 1/8” BTT are very close and the latter used in my current tractors. Have a nice assortment of metric fittings that I have yet to been able to use on the Kubota tractors. Some attachments are metric.
Bought four new pins for the M59 loader bucket linkage. Bought new zerks from dealer and they were BTT. Dealer doesn’t know what thread pitch they are. They go by part number.
Keeping track of three different thread pitches and multiple different sizes is a headache. Bought a thread pitch guide to help. A tractor with attachment could have three different types of fittings!
For a single tractor probably just better to get few extra fittings from dealer and label a pill bottle.
   / Kubota 3000 series Zerk fittings #6
I'd advise against getting Amascon (Chinese grease fittings), they are of poor quality. Never had a fitting failure but I use synthetic grease, not the cheap clay based grease that hardens in the fittimgs and plugs them up.
Not the pins that are subject to excessive wear anyway, it's the steel dog bones that get oval and if you reverse the pins (if they are worn) you then ride on a new surface. Had that issue with one of my M9's, so I had my dealer get me one dog bone and I did a CAD workup of it and cut them all on my Shop Saber CNC plasma table from flat stock. Much cheaper than buying 8 of them at almost 100 bucks each from Kubota. I cut 8 for about 30 bucks of steel flat plate. Onner and outers are all the same btw. I enlarged the pivot holes in the dog bones to accept bronze bushings I machined in the shop. The 660 CA bronze bushings will wear and can be replaced as needed. I made them an interference fit so they retain their position but can be pressed in and out when worn. How Kubota shoud have made them in the first place actually. I cut 8 and I've cut maybe a dozen more that my dealer has retrofitted to sloppy loaders he get's in as well. For some reason the upper dog bones oval out faster than the lower ones but the steel on steel is a bad design.
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
UNUSED 40' CONTAINER (A51248)
UNUSED 40'...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
UNUSED CHERY INDUSTRIAL 11' CATTLE SQUEEZE CHUTE (A51248)
UNUSED CHERY...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
