Kubota 3 point hitch arms
   / Kubota 3 point hitch arms #1
BobbyH
How high off the ground should the arms be on a Kubota L245 three point hitch? I bought a potato plow and cannot get it to dig into the ground, no matter how I angle it or adjust it.
I want to dig a 12 inch deep trench in Tennessee dirt (rocky and compacted soil) to run some PVC to the barn, about 250 feet from the water source.
The potato plow just rides on top of the ground, without digging in. I tried taking off the plow blade and just using the pointy frame as a subsoil pick, but no luck. I also tried loading it with 4 cement blocks, and that helped only a little. I am wondering if the arms of the 3 pt hitch are not dropping low enough to be effective. When at rest, they are about a foot up from the ground. Is that low enough?
I'm thinking maybe I should use my box blade with only one pick attached to start the trench, then follow up with the 'tater plow. :confused:
   / Kubota 3 point hitch arms #2
have you tried adjusting the toplink ? a full turn one way or another makes a difference.
   / Kubota 3 point hitch arms #3
I don't own a Kubota, but my three point arms will nearly touch the ground when fully lowered.
   / Kubota 3 point hitch arms #4
Just guessing here... adjust the toplink to be really short and see if that helps it to dig in. Without anything on the three point hitch, how low does the arms go? The arms can have some different setups... photos will help.
   / Kubota 3 point hitch arms #5
I fully agree with all said but it is possible you don't have a plow that will go into your ground. I have seen some potato plows that would only work in previous plowed dirt. The ones I have seen are made to dig the potato, not break the dirt for it.
Do shorten the 3 rd arm and try again.
   / Kubota 3 point hitch arms #6
Forgot this, the lift will not push the plow in the ground. The plow pulls itself in the ground if set up properly. The lift can stop it of course.
   / Kubota 3 point hitch arms #7
Do your 3 point hitch arms have two setting holes? Maybe you are in the set that won't lower the 3ph as far? I guess the question is how low do your hitch arms go without the potato plow on there? As someone said, they should be pretty low...like 3-4 inches off the ground.
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
UNUSED AGT NT18K EXCAVATOR (A51243)
UNUSED AGT NT18K...
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
City of Tampa (1611) VIN: 1FTMF1CM1EFB40793, **Title MUST be transferred into buyer's name (A51692)
City of Tampa...
