Kubota 2850 lift 500lb round bale?
   / Kubota 2850 lift 500lb round bale? #1
BTackett
Knoxville, Tn
Will a 2850 with FEL lift a 500 lb round bale to stack them? We are looking for another tractor and found this one. Owner says that he lifted 4ft round bales with it.
thanks,
Bill
   / Kubota 2850 lift 500lb round bale? #2
If it is truly only 500 pounds, then yes. 500 pounds is light for a round bail.
A lot will depend on how much rear weight you have. Also is it 2WD or 4WD.
You might be better off with a 3-point lift.
Lifting and moving a heavy bail is less stable than lifting and carrying a loaded bucket. (it is farther out there)
It is a 4 wd model. We can use the 3 pt on the rear to move the bale and when we get it to the barn use the FEL spear just to lift it up and move foward a few feet.
Bill
   / Kubota 2850 lift 500lb round bale? #4
Does the owner have any bales where you can try it out?
Will you ever be lifting any bigger bales?
I had an L3600 4WD and it would lift larger bales but is was very tricky manuevering. Anything but level ground and it would tip.
   / Kubota 2850 lift 500lb round bale? #5
The best spear would be one that connects in place of the loader bucket so the load would be closer tractor.
   / Kubota 2850 lift 500lb round bale? #6
Yes, I agree Art. We would remove the bucket and put a spear in its place. That would kill two birds with one stone. 1. place the load closer to the tractor and 2. the difference in weight without the bucket.
Bill
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2020 Bell TC-11A Crawler Carrier (A52384)
2020 Bell TC-11A...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
