Kubota 2850 lift 500lb round bale?
   / Kubota 2850 lift 500lb round bale? #1
BTackett
Knoxville, Tn
Will a 2850 with FEL lift a 500 lb round bale to stack them? We are looking for another tractor and found this one. Owner says that he lifted 4ft round bales with it.
thanks,
Bill
   / Kubota 2850 lift 500lb round bale? #2
If it is truly only 500 pounds, then yes. 500 pounds is light for a round bail.
A lot will depend on how much rear weight you have. Also is it 2WD or 4WD.
You might be better off with a 3-point lift.
Lifting and moving a heavy bail is less stable than lifting and carrying a loaded bucket. (it is farther out there)
It is a 4 wd model. We can use the 3 pt on the rear to move the bale and when we get it to the barn use the FEL spear just to lift it up and move foward a few feet.
Bill
   / Kubota 2850 lift 500lb round bale? #4
Does the owner have any bales where you can try it out?
Will you ever be lifting any bigger bales?
I had an L3600 4WD and it would lift larger bales but is was very tricky manuevering. Anything but level ground and it would tip.
   / Kubota 2850 lift 500lb round bale? #5
The best spear would be one that connects in place of the loader bucket so the load would be closer tractor.
   / Kubota 2850 lift 500lb round bale? #6
Yes, I agree Art. We would remove the bucket and put a spear in its place. That would kill two birds with one stone. 1. place the load closer to the tractor and 2. the difference in weight without the bucket.
Bill
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
Mitsubishi Mini Truck, 3cyl Gas Engine, 2WD (A52384)
Mitsubishi Mini...
