Loader Kubota 2320 loader valve
/ Kubota 2320 loader valve #1
Lea
Fort Frances Ontario
john Deere model M kabota 2320 TLB
My 2320 loader vv only works for up and down, the curl on the bucket stopped working today, has anyone else had this problem? The spool vv on the curl is like sized up ,could it be dirt or something of that nature, any help would be appreciated
/ Kubota 2320 loader valve #2
pull the cap off the bottom of the spool and look for ice/rust etc.
I will check that tomorrow but I don't think it is ice because I keep it in a heated shop, I had the loader off and when I put it back on I had a couple hoses wrong, could this be the problem
/ Kubota 2320 loader valve #4
yup...!
/ Kubota 2320 loader valve #5
Make sure your 3 pt lever isn't stuck. It happens all the time. Center the 3 pt and everything comes back to normal. I hope it is that simple for you. Sometimes it is and sometimes it isn't.
/ Kubota 2320 loader valve #6
Yes! There is a problem!
Try a search for B2620 won't dump-it's been in the last year.
A customer of mine had this same issue with his B2320 last year.Since his tractor was just out of warranty,he spent several hundred dollars on repair parts that required some work to fit correctly.
He had to remove a rear tire to acess the loader valve.
I suggested he contact the dealer to see about this issue.
Maybe somebody can do a search for B2620 Won't Dump and post a linkfor you?
Good Luck!
/ Kubota 2320 loader valve #7
The valve on my 2620 was replaced last year when it did the same thing. Dealer mentioned that they had seen a few of these valve problems. Looks like a known problem and might be covered by Kubota. Good luck!
/ Kubota 2320 loader valve #8
Pull all the hoses off and reseat them. Mine did the exact same thing when I had one of them that was not pushed on all the way.
Rob
2020 Deere 670GP (A64126)
2020 Deere 670GP...
OVERHEAD PROJECTOR, HP PRINTER, (2) MONITORS (A64276)
OVERHEAD...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
