Kubota 2250 Fluid leak
   / Kubota 2250 Fluid leak #1
tractor_john
I have a 1987 Kubota 2250 with 418 hours. Recently I noticed a small drop of oil coming out of a brass bolt on the bottom of the transmission. The bolt is directly behind the oil pan and has a metal pin in the middle that slides freely up and down. The oil leaks out of this area. What problem and how do I fix?
Thanks.
   / Kubota 2250 Fluid leak #2
That is there to allow two things, engine oil that is leaking from the rear main, and / or transmission oil to get out with out getting on the clutch disk and causing slipping. The loose pin is made to shake and vibrate to keep the hole open. A slight drip should keep you checking for low fluid levels, but I'd learn to keep an eye on it if not a lot. All cures will involve splitting the tractor at the least to correct. This is an older tractor and a slight leak is to be expected
Tires (A50322)
Tires (A50322)
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
Toro Mower (A50324)
Toro Mower (A50324)
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
