Comparison Kuboda 3200N vs New Holland T1510
   / Kuboda 3200N vs New Holland T1510 #1
mhelmst
Trying to figure out which on is a better deal or which one would be better for me. I just bought a new house in Michigan on a large piece of land and will be maintaining 5-6 acres, my drivewat is about 250 feet long. I have never owned a tractor before but i need to get on to cut my grass and plow my driveway in the winter. I am considering either a Kuboda 3200N or a New Holland T1510 both with a 72" belly mower and a 60" loader. I have quotes for both and they are within $500 dollars. Any advice would be great.
   / Kuboda 3200N vs New Holland T1510 #2
what is a kubota 3200N? is that a new model or older? I can give you info on the kubota and NH, just not sure what the 3200N kubota is? thanks
   / Kuboda 3200N vs New Holland T1510 #4
In the Kubota Forums you will see some discussions on the vibration of the 4 cyl engine used in the B3200. We test drove a B7800 which had the same engine and definitely noticed it and it becomes more pronounced as you increase the RPM. This is not to imply it is a bad engine, but only to suggest you test it and see if it will bother you. I would not want to spend that kind of money and then be disappointed. It is apparantly a balance issue with 4 cyl engines. Some owners seemed to be more bothered than others.
   / Kuboda 3200N vs New Holland T1510 #5
I own a B3200 and it has a 4 cyl diesel engine, I do not feel or notice any more vibration then any of the other brand tractors that I had in the past. Some were larger and some smaller. I believe most of the posts talking about this vibration issue could have come from owners who never owned or operated tractors before.The Fords and the Olivers and even a quite large International 1486 vibrate at certain RPM's.I guess what I'm trying to say is your on a tractor not a Cadillac, some vibration is expected
Hyster H225E (A47384)
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
