Comparison Kuboda 3200N vs New Holland T1510
   / Kuboda 3200N vs New Holland T1510 #1
mhelmst
Trying to figure out which on is a better deal or which one would be better for me. I just bought a new house in Michigan on a large piece of land and will be maintaining 5-6 acres, my drivewat is about 250 feet long. I have never owned a tractor before but i need to get on to cut my grass and plow my driveway in the winter. I am considering either a Kuboda 3200N or a New Holland T1510 both with a 72" belly mower and a 60" loader. I have quotes for both and they are within $500 dollars. Any advice would be great.
   / Kuboda 3200N vs New Holland T1510 #2
what is a kubota 3200N? is that a new model or older? I can give you info on the kubota and NH, just not sure what the 3200N kubota is? thanks
   / Kuboda 3200N vs New Holland T1510 #4
In the Kubota Forums you will see some discussions on the vibration of the 4 cyl engine used in the B3200. We test drove a B7800 which had the same engine and definitely noticed it and it becomes more pronounced as you increase the RPM. This is not to imply it is a bad engine, but only to suggest you test it and see if it will bother you. I would not want to spend that kind of money and then be disappointed. It is apparantly a balance issue with 4 cyl engines. Some owners seemed to be more bothered than others.
   / Kuboda 3200N vs New Holland T1510 #5
I own a B3200 and it has a 4 cyl diesel engine, I do not feel or notice any more vibration then any of the other brand tractors that I had in the past. Some were larger and some smaller. I believe most of the posts talking about this vibration issue could have come from owners who never owned or operated tractors before.The Fords and the Olivers and even a quite large International 1486 vibrate at certain RPM's.I guess what I'm trying to say is your on a tractor not a Cadillac, some vibration is expected
2010 Toyota Camry Sedan (A50324)
2010 Toyota Camry...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
Electric Golf Cart (A50121)
Electric Golf Cart...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50323)
2006 Imperial 14Ft...
