Backhoe KPX Backhoe.....Who has one?
   / KPX Backhoe.....Who has one? #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
I clicked on the TBN link above. Seems like if i added a subframe mount it would be all i want....er...need. At 1/2 the price it is tempting.....
Comments?
RD
Ok, the KPX rep caled last night and said that their hoe is not designd for use with a subframe. I thought any 3pt hoe could be adapted:confused: . Oh well, it was a thought anyway.........
RD
   / KPX Backhoe.....Who has one? #3
RD
You and he are both correct. THEY didn't design it for a sub-frame, but YOU can adapt it to work with one. Will need to build the frame and weld on some attachment points to the hoe. I have not done one, but the project is pretty straight forward. If you do a search on building subframes, you will find several projects.
jb
   / KPX Backhoe.....Who has one? #4
What is the danger of attaching a back hoe on a 3 pt as against a sub frame mount.
I anticipate digging 2-3 ft deep drainage trenches, removing small tree stumps and arranging log piles. I have a 2210
   / KPX Backhoe.....Who has one? #5
We sell the LITW korean backhoes, 300 % better quality than the chinese backhoe, JIC fittings, USA hoses,Swedish valves, Powder coated paint.They have there own tank and PTO pump,they also make a sub-frame that you could modify for your tractor.Very nice units
Tommy
Affordable Tractor Sales
Bellville,Texas
AFFORDABLE TRACTORS
JB, thanks, i'll look into it further.......
Deerman, the general consensus is that without a subframe, the hoe will put too much strain on the 3pt, which was not designed to have that kind of force applied to it. The cost of the subframe is minor compared to the cost of the hoe, so it makes good sense to use one.
RD
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
Case Titan 3530 (A56435)
Case Titan 3530...
2025 AGT STSD10 (A56469)
2025 AGT STSD10...
