Koyker 160 FEL Right side brackets dont fit Jinma
   / Koyker 160 FEL Right side brackets dont fit Jinma #1
GuglioLS
Edgewood, NM USA
Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
Well I went to install the Koyker 160 FEL onto my brand new 2005 Jinma 354 LE. I started on the left side and installed all the brackets NO PROBLEM it went smooth. So I figured well this is a breeze lets start the right side then OMG WTF, this is not right. Take a look at the three photos I am posting.
First I had to remove the clutch inspection side plate to install the FEL mounting brackets - no problem. But when I went to mount the FEL bracket it does not completely cover the inspection hole and all the bolt holes do not line up. Additionally the bracket will not go into place because it is hitting the Hydraulic lines coming out of the Hydraulic pump.
MY QUESTION :
Has anyone installed a Koyker 160 FEL onto a new 2005 Jinma 354? If so Please send me a photo of the right side mounting brackets.
I have e-mailed my dealer and will call Koyker first thing Monday to see what they have to say.
Stay tuned.........................................
Problem & Photo # 2 Mounting Bracket & Hydraulic line conflict.
   / Koyker 160 FEL Right side brackets dont fit Jinma #3
Obviously they sent you the incorrect mounting brackets. Give Koyker a call, they are real helpful.
   / Koyker 160 FEL Right side brackets dont fit Jinma #4
I have the 140 Koyker on a 284 LE but it came installed on the tractor from the dealer. I did however have to change the bracket on the front of the loader frame so that I could open the hood without taking the bracket loose. I viewed your pictures in the other post, very good looking machine and a good job of your step by step assembly. I too think that Koyker will get the correct part to you very quickly.
   / Koyker 160 FEL Right side brackets dont fit Jinma #5
You have the wrong bracket,you need the LE bracket.I think the one you have is for a non-LE
The right bracket is the only one that changed on the LE. The right bracket completely covers the big hole,and the small inspection cover stays installed.
However since you drilled out the other bracket, I doubt Koyker will take it back now
Tommy
Affordable
Tommy
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
2015 KENWORTH T880 MID-ROOF SLEEPER (A52472)
2015 KENWORTH T880...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52748)
2022 Quick Attach...
Airco Tig Welder (A51691)
Airco Tig Welder...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
