Koyker 150 hydraulic pump question
/ Koyker 150 hydraulic pump question #1
BrianFranklin
Shenniu 4/25 with a koyker 150 loader
Hi everyone I’m new to the site and have a question. I’ve bought a tractor with a loader. The tractor is a Shenniu 4/25 with a Koyker 150 front loader. From my research the tractor is from the mid 80’s. When I first got it it worked pretty good. I replaced the seals on 2 of the loader cylinders and it still was working property. We’ll I guess I didn’t tighten something up, but for some reason all the hydraulic fluid leaked out. I ran the pump dry until smoke/steam came out of the reserve tank cap. Long story short is that I need help sizing/finding a replacement pump. The pump was rigged to the flywheel of the tractor and is belt driven. Any help would be appreciated. PS I have very little knowledgeable about things like this. Thanks
PS it appears that the system needs a pump with 5GPM and 2200PSI.
/ Koyker 150 hydraulic pump question #2
You can try taking the pump to a local hydraulic shop, they may be able to rebuild it.
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
Champion X18A Air Compressor (A65640)
Champion X18A Air...
Bobcat SC72 (A64126)
2005 GMC C7500 (A64127)
2005 GMC C7500...
