Tiller Kounty LineTiller
   / Kounty LineTiller #1
buckstar25
Ohio
Yanmar 186D
First, it is spelled with a K but everything I have found is spelled with a C. No biggie but kind of frustrating when trying to troubleshoot.
I am not out at the house so I don't have the model number available but it is the 4' tiller. Yesterday while breaking new ground the outer side case seal blew. Most of the oil leaked out onto the top of the unit. I can't find any solid help on my own, so here I am. The unit was bought at TSC in Ohio and was at a discounted (used) price.
All maintenance has been kept on it since we have had it, fluids maintained and checked before each use. There has been no issues before this other than tightening a few bolts on the case after we filled it for the first time. The tiller is used the most (approximately 1 hr) tilling our food plots. The rest of the time it sits. So the following are a few questions.....
1.) Who actually made this tiller KK or Tater? Will the model # tell us this?
2.) What could have caused the seal to go bad? I know the unit does not come filled from factory and can't say it had correct amount in it from previous owner.
3.) What do I need to look for, as far as damage to the gear/bearings when replacing the seal?
4.) Why does the manual say to contact TSC for parts but TSC says to call the manufacturer?
Sorry for the long post and thanks in advance for any info. I will answer any and all questions.
   / Kounty LineTiller
Just to clarify, it is the outer seal on the side gearbox.
   / Kounty LineTiller #3
You can buy king kutter parts directly from king kutter, but if the tiller is made by tarter you have to go through tractor supply.
   / Kounty LineTiller
Thanks, any recomendations on what to look for, and what may have caused the seal to fail?
   / Kounty LineTiller #5
Put lock washers on the bolts. Mine worked loose and I noticed the seal starting to leak. Lock washers or blue locktite helps with all the vibration. Check them often.
(3) PALLETS OF HEATERS (A55745)
(3) PALLETS OF...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
