Korean tractor dilemma
   / Korean tractor dilemma #281
Talked to dealer yesturday. They claim they cant find the hst leak, even though i showed them when i dropped it off. So i sent them pictures of it and where it is. The oil pan leak they are "investigting" not much to investigate. Its leaking on the back side of the oil pan near the rear main. Maybe i should suggest they use dye if they are that incompetent
How heavy is the leaking? We talking a few drip stains over a week sitting in one place, or are we talking a cup of fluid in a day? Does it leak when off, or just when running, Any chance it had leaked to the point of the sump being dry?
No idea what spec is; but some cars now are "within spec" if they loose 2 quarts or less of oil in a 5000 mile period
   / Korean tractor dilemma #282
Or are we talking dust sticking to areas, and no drips?
It leaves a 6in spot on the floor under the machine.. when they say loose 2 qt of oil they are talking about consomption not leaking. Hst pump should not be leaking any way as it is a preasurized system. If its leaking it has a failor some where
   / Korean tractor dilemma #285
They seem inept if those are not signs of leaks
Emailed the regional ls rep this afternoon. Told em if the ball does not get rolling that i will be getting out side sources involved. See what he has to say. If i dont hear from him mid day i will call HQ. Had enough
dealer called claimed tractor is done, all they fixed was the oil pan. Still standing firm that they couldnt find a hst leak. Im sick of arguing with them so i picking it up. Charged 45 for the oil and filter, 100bucks in trailer rental for drop off and pick up and about 100 in gas. So 245 ish for a project that would have cost me 40 bucks and a weekend. Putting dye in the hydraulic oil when it gets home, will end up having to take it back once the fluid with dye shows up.
Picked tractor up today, dealer said it was done. They fixed the oil pan , but stood firm on the hst not leaking. Before i left i noticed a loose bolt on the loader frame, they had taken it off. I showed them and had them fix it before i left. Once i got home i started looking the tractor over and had to go through the entire thing. All the mounting bolts for the frame and loader frame were hand tight on the left side of the tractor. I still need to check the right side. Mounting bolts were missing there lock washers aswell. I checked there work on the oil pan and there is a large amount of silicone squeeze out, on the out side of the pan. I can only imagine what the inside looks like, if it breaks off it will plug the oil pick up and starve the motor of oil. I also found that they bent the hydraulic line cover on the loader from it hitting the bumper when they took the loader on and off. Finally i got to checking on the hst pump, they sprayed it down with a cleaner but they is already a drip of oil starting to form on the bottom of the pump. Using a mirror and a light i can see the front of the pump is wet of fluid in the bell housing. So i am going to have to purchase uv oil dye so i can track the leak down.
So i have around $120 in fuel , $100 in trailer rental, 8 hours of time taken off of work to haul it around. Just to get back a tractor that has damage, not put back together correctly. That i ultimately am going to have to take back to a dealer for the hst leak, that i am also going to have to spend money on dye to diagnose it seeing how they werent able to.
   / Korean tractor dilemma #290
Ok, so I'll skip right to my point, s
I think you are going need to just sell the machine. You shouldn't take too much of a hit, as it's a low hour, nothing wrong with it machine.
Now, the longer version, kinda explaining my thinking; after multiple hours of sitting, unloading, and moving the machine "a single droplet has started to form, but not enough to actually drip". You're not going to get that fixed, and I don't think you're going to win a case... So, at this point, you're basically mad at the manufacturer, service guys, company, and the tractor. Every time you see a drop of oil, you're going to get mad again. Sell it. There is nothing wrong with it, so no need to disclose anything; it's time to just move on.
We aren't even talking about a kinda "leak" that needs monitored, we are talking about even over 250 hours, probably a fluid loss of less than a single cup; out of like 7 gallons.
Now, you are displeased, and I understand, but at most, and this is a stretch, it's a cosmetic issue, that is hidden. I do get the idea that leaks general only get larger over use/time; but I don't think it's the dealers responsible to do a $5k repair, based on that it Might eventually be a problem, 5 years from now.
Edit: I know you're not going to take what I said in the way I mean it, that's why I lead with the first part. Like what I said or not, the first paragraph still holds true
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
LIGHT TOWER (A56857)
2013 COACHMEN CATALINA TRAVEL TRAILER (A58214)
2013 COACHMEN...
2013 KUBOTA SVL90-2 SKID STEER (A52709)
2013 KUBOTA...
2020 Chevrolet Tahoe SUV (A56859)
2020 Chevrolet...
golf cart electric (A55787)
golf cart electric...
