komatsu d21a-7 track pin
   / komatsu d21a-7 track pin #1
tuttle
central oklahoma
komatsu d21a-7
how do u get the master track pin tite in link? parts are new. <font color="red">
   / komatsu d21a-7 track pin #2
Send a PM to DarinRay. He is a Komatsu importer and may be able to help you.
Otherwise you can to to the IBDozing forums and someone there can surely help.
   / komatsu d21a-7 track pin #3
If you have a new pin and new links and they are not tight then the pin is not right for the link you should have to drive the pin in with a LARGE hammer. On a dozer anyway some excavator links use a roll pin to keep them in but not dozer or loader tracks
   / komatsu d21a-7 track pin #4
My old dozer's master link pin used roll pins but it still took a sledge to install or remove it. It was an IH from 1972
thanks for replies dealer said vendor made pin to small said ok to weld it on end. instead i heated pin 1/2 inch from each end & hit it 2 times with 8# hammer then turned it down to .030 over dia. & drove it in to link. have old rails & pads are they worth any thing or just scrap metal? thanks
   / komatsu d21a-7 track pin #7
tell the dealer you want the right size pin yes you can weld them but most of the time they will brake. same for expanding the head of the pin the pin should be tight for apx 1-1/2 - 2" on each end or you will most likely ruin the new links from the pin working in them
1263 (A50490)
1263 (A50490)
Bad Boy 747cc Outlaw (A50121)
Bad Boy 747cc...
24' Free Standing Panel with Swing Gate (A50515)
24' Free Standing...
Wolverine Skid Steer Drum Mulcher (A50515)
Wolverine Skid...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
