Komatsu D20A track tension
   / Komatsu D20A track tension #1
bwj123
Williamsport
komatsu d20a
I am trying to get my track adjusters to work with no luck. I have books, manuals (none worth a sh..) and someone in the business, but we are stumped as to how to proceed. Anyone out there with a background in Komatsu "recoil spring" track adjusters for this small dozer? Thanks, Brad
   / Komatsu D20A track tension #2
I'm assuming these are standard hydra-justers, as we called them. There should be what appears to be an inspection cover approx. 6" X 6", or so near the front of the cover, over the adjuster assy. Possibly a section of the cover over the barrel of the adjuster, that is removable. Under there, you will find a grease zerk. Give it a few shots at a time, then pull up, and back up a couple times, letting it take the slack out of the track. Then check the sag in the track, with a straight edge. Usually a good inch was pretty decent.
If you pump them up too tight. Under the zerk on what we had, looked to be a nut about 3/4" or 1" depending on the size of the tractor. Back this out slowly, and it will release grease, and tension off the track. Just go a bit a a time, until you see grease coming out.
Not really familiar with a Komatsu, but the Case, John Deere, and Fiat-Allis we had were pretty much the same in principle.
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2010 FORD F-150 (A53843)
2010 FORD F-150...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
